tachometer
More threads by Des
Des
Australia
Can anyone please tell me which cars came with the tachometer? Or was it an option accross the board?
I think every 450SEL I have seen has had a tacho, what about the other cars?
Seems most if not all 280S's\SE's don't have one
HansKruger
Hobart
Des the tacho was optional accross the range
The 450 models generally had it standar
Are you going to fit one to that clunker I saw you in?
Hi Bill, this is two Taswagians (Tasmanians) at each other's troats - give them some room !:D :D Regards Styria
The Australian 450's were all delivered with tacho's as standard. Any 450 you see in Australia without a rev counter is a private import, mostly from the UK which had a large clock in the same location as our rev counters.
116Benz
Forest Lake, Brisbane QLD
I dare say the likes of 280S had the tacho optional, the 280SE's I looked at all had tacho's on them, I think the V8's had them standard.
116Benz
Your not going to go the fulleh sik supa cheap monster taco with shift light are you Des?
haha no, more like bruise my fingers and lots of swearing while I try to remove the cluster from a 280SE here at the wreckers.
That was gonna be my suggestion..
Good luck
Z a bit confused on the tachometer readings Mechanicals 12
