As Sydneysiders would know, we have experienced our fair share of quite hot days - many times at least 34 degrees centigrade, but even hotter days when temperatures have reached more than forty degrees.
Gleaming Beauty, my 6.9, is a daily driver and as such, the mechanicals and cooling system have been exposed to these conditions. How many others in this group use their 116s on a daily basis and how do you find the cooling system coping with these heatwave conditions ? For instance, yesterday with temperatures in the West being close to the 38 mark, and with heat coming off the road surface like you wouldn't believe, I saw the temperature gauge needle just going over the 100 mark - normally 100 can be reached quite quickly (perhaps disturbingly so), but seldom will the needle go over the 100 mark.
Naturally, the auxiliary fan being of the 85 centigrade version, is forever working away quite furiously, as well as noisily. In fact, the din coming from it , again can be quite disconcerting. The question I have, or the opinions I am seeking from others, should one be concerned with these temperature readings ? The cooling system, to all intents and purposes, is in excellent condition, and I am still running an 87 degree thermostat. There appear to be no issues with the way the car is performing, but I just wonder to what extent the cooling system can be considered to be only just adequate to cope with really hot climatic conditions. Regards Styria
