Or there are now a few E500 W211 under 20K http://www.carpoint.com.au/all-cars/dealer/details.aspx?R=AGC-AD-15513866&Cr=2
1) Engines and transmissions should be bulletproof if serviced correctly.
2) Earlier models 2002 to about 2005 used memory system that could be lost if the main battery and small backup battery were flat together
3) Post 2006 models used more stable memory that sustained toital power failure.
4) Cost of repairs to Airmatic DC might cause a nose bleed if necessary.
Okay, you're talking to the unknowing. SBC - what does it stand for ? Also, loss of memory - what are its implications ? Had a bit of a look regarding Airmatic, and a video on You Tube illustrated connection failure of a hose fitted to the air pump. Apparently that hose was the subject of a modification in design which eliminated the offending connection. Regards Styria
Thread starter | Title | Forum | Replies | Date |
Farewell ML500 - Welcome W212 E500 | Talking Torque | 5 |
