componant picture
:) Hopefully added a pretty picture of the cannister controled by air tube from hose connection to the valve cover which evacuates the fumes. Sean
So Sean, what is the unit doing wrong, or what problems are you experiencing ? Regards Styria
No Problems Styria, I just wan't to know what it is for. As I do 99% of my own work, I need to know where and what the sensors etc., etc. are , and for. I don't understand the unit being controled by air flow/speed and not a vacumm source. An enrichment device would be more responsive to engine load ie vacumm. I've been all through various K Jetronic web sites and can't see this unit on any of them except for a picture of a Euro 110 engine where it is clearly visable.
On modern vehicles there are sites that show and identify sensors , relays and locations. Under the bonnet of a modern , unfamiliar , car is like looking into the back of a T. V. Set ! ..............Sean
Isn't that a fuel pressure regulator that alters pressure depending on engine load/vacuum??
BTW if we wanna be accurate, it's spelt 'componEnt'!! :)
S componant K Jetronic Mercedes R/C107 6
S componant location Technical Information 0
