From the horses mouth, from a friend who was Service Manager and Transmission specialist of a major Benz Dealership in the eighties. His simple fix was adopted by Mercedes . One drill size up for the clutch feed to 4th gear in the valve body seperated plate. Mercedes supplied a modified plate as a Service fix. I'll get the exact detail from him and post it. There is nothing new in this type of modification on other transmissions , mainly some Fords. The trick is to find the right feed hole and the right drill size. This type of alteration is only as an as necessary basis as you may end up with a harsh shift. Other transmissions , eg., FWD Jacto respond by closing up the top gear clutch clearance. Trial and error is still alive and well. .... Sean
