Blowing the cobwebs
After passing Styria's Fiefedom I crossed with the Ferry and decided to kill or cure a noise in the Turbo Golf that was coming in at 2500 Revs. Sounded like a light bearing rattle with a slight harshness up the Rev. range. I had noticed this a while ago, Turning right along the water way to Peats Ridge, the road is winding and fast in places, so driving up and down from near idle and between 5 & 6000 Revs in 2nd and 3rd gears for about half an hour. Problem solved ! Engine feels freer, smoother, and the rattle noise gone . 8000Ks on Odo with a recent Service using VW Spec. Oil.
The misterys of life.
Apparently it is the waste gate arm rattling. New clip should fix this and if not "tighten the waste Gate arm" Maybe I gave it a big fright ! Still two years warranty left if needed.
