Ok........
So I had a lengthy conversation with someone yesterday who know's most MB Models back the front.
Being I've been trying to get enough parts together to put brand new leads onto the 6.9 i'm now at the point where half the 5k Ohm supressors have not come off the old leads properly (the screw in bit stuck inside) and the 90deg dist cap ends have nearly all snapped off and not un-screwed correctly. So I have new Magnecor lead and not enough ends to make new leads.
So... that led us to a conversation about why a 6.9 should have 5k Ohm's resistors and a 450 only 1k Ohm's resistors - when the ignition module thingy are actually the same module for both cars.. same ignition system.
Apparently Bosch who made the ignition system later claimed there was no real need for different resistors, but Beru who made the leads / resistors persisted that there did need to be a difference.. (I may be quoting this wrong - so don't shoot me down).
Anyway, is there any specific fact that states why I need the 5K ohm resistors for a 6.9??
And, would there be any issue with using the 1k Ohm factory Beru leads at all?
Cam.
Cam.
