280 SL cruise control
Have fitted an after market electric Cruise control to my Grey Import 107 280
S L . Works like a charm ! I'm very pleased with the car now, Auto sorted , Air sorted, engine purs like a kitten and with new Michalen tyres , it is smoother than our new C200.
Thanks for all the previous suggestions ..... Sean
Fantastic news!! Any pics?? :)
Good day, Sean. Good to hear from you. As a matter of considerable interest, do you think you'd be able to forward details of the work carried out, what was involved and, if you are comfortable enough about, would you be able to tell us what it cost ?
On our 116s, cruise control units are quite troublesome on account of their age, and an after market alternative could well provide an excellent alternative. Regards Styria
Another specialist who has been a big help is Jeff from Afordable Radiator Repairs. 98995041 He has the equippment and rebuild kits for the York Air Con. Compressors. We rebuilt mine togather, be does not mind working this way as long as you know what you are doing. ........ Other work carried out.......
To get "any " Auto Trans to work properly it is essential to have good vacuum i.e,. the engine tune right. For my SL with the 110 DOHC six that ment with vacuum disconnected 36 % mechanical BTDC at 3500 RPM. The 750 idle came in at 10 % before, so the distributor was not worn. Check that the retard and advance vacuum is working ok . Without the idle retard working the engine tends to stall in traffic. An engine pulls better with slight retard, learned from my Motor cycling days riding Trials Bikes. With this sorted the 3-4 flare was sorted by a careful balance of modulator adjustment and shift speed control cable. The shifts are sligtly late on medium throttle but ok on light - medium with nice part throttle kick down. Desirable with the smaller 2.8 engine.
Sorry if I'm preatching to the converted , but you did ask ! Regards Sean
S 280 Coupes Gumtree/eBay/Facebook Listings 2
L Manual 280 with "Extras" Gumtree/eBay/Facebook Listings 1
carl888 1974 280 se w116 Mercedes W116 14
A FS: Mercedes-benz 280 SE (1978) requires new loving home Gumtree/eBay/Facebook Listings 0
motec 6.9 Nice 280 se coupe for sale Mercedes W110, W111 and W112 3
300SDude 1968 280 SL Turbo Diesel Gumtree/eBay/Facebook Listings 3
300SDude OMG! BEAUTIFUL1966 Mercedes 250SE / 280 SE Convertible W111 Gumtree/eBay/Facebook Listings 5
Oversize A couple of 280's for sale in NSW Gumtree/eBay/Facebook Listings 1
T M110 280 motor Mercedes R/C107 6
B Tested out the aircon and cooling on the 280 today>>>>> Mercedes W116 9
B For the manual 280 fans: engine + box $250 starting bid Gumtree/eBay/Facebook Listings 20
O 280 S problem areas? Mechanicals 8
SELfor50 1 Hour To Go! [280 SE - VIC] Gumtree/eBay/Facebook Listings 5
SELfor50 W116 280 SL for sale?! Gumtree/eBay/Facebook Listings 3
A Cruise control Mechanicals 4
Oversize 6.9 40th Birthday Cruise Car Show Photos 50
S Sensors Rev. Cameras Cruise Controls Recommended Suppliers 16
S Cruise Control Recommended Suppliers 0
BenzBoy Cruise control in wet weather? Mechanicals 13
B Fitting aftermarket cruise control? Mechanicals 6
Michel Cruise Control Mechanicals 36
WGB Vacuum Lines to Cruise Control Modulator Mechanicals 5
G Alternative Cruise Control Mechanism Mechanicals 1
c107 Rebuilding 6.9 level control valves Mercedes W116 1
Styria In-Depth guide to 6.9 emission control Articles 6
WGB Installing a LHD Climate control fan in a RHD HVAC car Mechanicals 1
B 6.9 upper control arms Mechanicals 14
B Heater control panel in the console - how do I remove it? Mercedes W116 4
