280 S problem areas?
More threads by oldsalt77098
O
oldsalt77098
I have an opportunity to add a 79 280 S to my fleet but am a little worried about the carburetor and the DOHC.
I really want another 116 body but should I be looking at something else?
Is this a little too specialized and hard to get parts for?
Thanks,
Oldsalt
116Benz
Forest Lake, Brisbane QLD
Not really, the 280S shared the same 280SE M110 engine, albeit carby instead of injection. Parts? www.autohausaz.com has plenty of parts for 280S' most of the interior stuff is the same as 450SE's the only difference is the 450SEL has longer back doors.
Thanks,
Oldsalt
Some might say you're lucky to get a carburetted car instead of the injection ;)
Go for it...
Don't fear anything
I have to agree with Michel. There is nothing to fear. Indeed, if the car appeals, no matter what it is or what it is like, there is nothing to fear. And I think I should know - given my latest journey into the land of the long white cheque!! :eek: Parts are available - and so is advice through this site. Go for it and enjoy.
Martin280s
Jundiaí, Brazil
If you have any problems with the 'lovely' Solex 4A1 you just need to ask.
I have worked a lot on mine to get it spot on....which wasn't easy. The workshop manual for this carb is almost as big as my complete workshop manual for the W108! There's a lot of reading but it's not as bad as many suggest.
I'd probably put a spanner in the works by suggesting that an injected car would be my preference. Although never having owned a carbie version of Mercedes other than a 1959 - 190B, I am not qualified on the subject. It's only what one hears around the traps, and Merc carbies, especially in the late '60's and early '70's versions don't enjoy a good reputation.
Just make sure that the car runs well either hot or cold before you commit yourself to the purchase. Regards Styria
That is good advice Styria about checking that it runs well both hot and cold. Carburettors can be an issue and for Benz can be hideously expensive to fix. However, if originality is not the goal then there are substitute carbies which will do the job at a reasonable price.
Andreas
Adelaide
Hi I have just bought a 280s. Think they are a nice car.
Plan to take it racing. Needs some tender care and attention. Carbie is the original solex. Needs some fixing carbie that is. Like to keep the car original as manual and on Historic registration. So any help with carbies would be appreciated. Currently trying to get the water pump off as leaking. Also thermostat not working stuck open. Once car cooling system working properly will play with carbie as running realy rich.
Any help appreciated on the carbie as have never played with one in my life.
Cheers
Andreas
Craburettors vs Fuel Injection
Well comparing a Carbie with a 2008 'modern' Engine Management System is like chalk and cheese.
Easiest way to put it. Carbies, Ignition Coils, Distruibutors etc were simple mechanical devices that proved reliable and inefficient. Engine Management Computers, Independent Coils, Multi-Point Injection etc are complicated electronic devices that provide better engine runiing giving increased power, better running under all loads and conditions [cold start, warm running and hot running], but have a relatively short life and cost ten times more to replace.
For historic events, one should be certain that the car complies with all regulations of the class of vehicle.
Best to 'stick with what you've got': changing from carb to Engine Management [even early 'crude' - ignition control modules'] will cause you to make dozens of changes to a carbied engine. You'll have a little less power but again need far fewer headache pills and dollars to maintain the vehicle.
S 280 Coupes Gumtree/eBay/Facebook Listings 2
L Manual 280 with "Extras" Gumtree/eBay/Facebook Listings 1
carl888 1974 280 se w116 Mercedes W116 14
A FS: Mercedes-benz 280 SE (1978) requires new loving home Gumtree/eBay/Facebook Listings 0
motec 6.9 Nice 280 se coupe for sale Mercedes W110, W111 and W112 3
S 280 SL cruise control Mercedes R/C107 3
300SDude 1968 280 SL Turbo Diesel Gumtree/eBay/Facebook Listings 3
300SDude OMG! BEAUTIFUL1966 Mercedes 250SE / 280 SE Convertible W111 Gumtree/eBay/Facebook Listings 5
Oversize A couple of 280's for sale in NSW Gumtree/eBay/Facebook Listings 1
T M110 280 motor Mercedes R/C107 6
B Tested out the aircon and cooling on the 280 today>>>>> Mercedes W116 9
B For the manual 280 fans: engine + box $250 starting bid Gumtree/eBay/Facebook Listings 20
SELfor50 1 Hour To Go! [280 SE - VIC] Gumtree/eBay/Facebook Listings 5
SELfor50 W116 280 SL for sale?! Gumtree/eBay/Facebook Listings 3
P gauge problem Interiors 7
S Wiring Factory Problem Articles 2
D Problem with 3.5 w109 Mercedes W108 and W109 2
WGB Houston - we've got a problem Interiors 5
