HELP! Which m110 engines are K Jet that fit the 280 SLC
More threads by Trippstick
Trippstick
Gold Coast
Hi People,
I have a 1978 280 SLC and I need a new engine for it, I have found a 1980 280 SE however he doesn't know much about cars and was under the impression that it was running the old injection system (would that be D Jet?) as it was imported to Australia from South Africa as they don't have the emmission controls over there that we did here.
I am hoping that its a K Jet but I have no idea how to tell the difference if I go and look at it.
Would you please be able to help me out, it would be greatly appreciated!
or if you know of a good cheap m110 engine around Gold Coast.
Kind regards
Trippstick
My advice is to put a 6.9 in it, or a Prius driveline:eek:
T
Trippstick
Gold Coast
Yeah sorry about that guys, been over working in Singapore since mid June, I only just checked your responses last week. That being said I did reply to everything origionally on the first page just not the few replies on the second page ie. after I left
if its a 1980 280SE it will be K Jet. D Jet Ceased in 1975/6.
If you post a pic its easy to see the difference.
T
Trippstick
Gold Coast
Thanks Helmet,
Its in a donor car that I am looking at buying, hence I can't get a picture, just wanted to make sure first.
Would the engine be a straight swap into the 280 SLC?
If not do you know which cars have an engine that will be a straight swap into the 280SLC?
Thanks Helmet,
You will probably have to use the current exhaust manifold on the SLC and maybe swap some more fittings
Thanks Helmet,
Hope the "donor " engine is ok ?
As Michel said, you will need to swap exhaust manifold + engine support brackets, accelerator linkage and some piping for power steering .
Good luck
T
Trippstick
Gold Coast
Good luck
Thank you for this, that doesn't sound like much work for the exchange, the engine is okay and is in a running car now, has 229,000kms but its an old retiree who has owned it for its whole like and apparently has all the paperwork servicing etc and is in a registered driving car right now.
I can buy it for $600 then scrap the car for about $300 so its really only cost me $300 for the engine plus $900 labour which works out to be $1200 give or take, does that seem reasonable?
Go for it...
It is excellent value
S Help Articles 2
marie_70 Need help for w109 016 300sel/8 6cyl Articles 32
BenzBoy Help needed please. Technical Information 17
BenzLover Tech help please. Mechanicals 1
grant v Please help save the East London Grand Prix Circuit - South Africa Motorsports 1
motec 6.9 SSK replicar with m110 Talking Torque 1
T M110 280 motor Mercedes R/C107 6
M First time pulling an engine (m110) suggestions? Mercedes W116 11
G M110 motor - yours for FREE ! Gumtree/eBay/Facebook Listings 0
Des A question for M110 owners Mercedes W116 6
Des Some thoughts on the M110 engine(s) Mechanicals 13
Michel Cheap VRS Kit for M110 ? Gumtree/eBay/Facebook Listings 1
S A Class engines Mechanicals 4
S 107s with 110 engines Mercedes R/C107 4
Oversize Name your Favourite 3 engines Talking Torque 14
