Injection pump replacement. Part 2
More threads by abl567
I installed the spare pump today after making new gaskets and sealing with Locktite 518, great stuff.
The pump went into place easily enough
However it was not lined up right
A few more contortions and twists and it all lined up and slide home
now to set up the regulator linkage
Hi abl567, I just need to ask you some pertinent, and perhaps, impertinent, questions.
Prior to removal of the other pump, at what position did you have the crankshaft at ? At the recommended 60 degrees ATDC ? As you know, that's critical. Also, how do you set up the regulator linkage ? It will, indeed, be very interesting to see how your car will perform, and if it will perform correctly with the replacement pump fitted. Regards Styria
Hi Styria,
Yes I set the crankshaft to 60 degrees ATDC at cylinder 1, both are critical to correct pump timing.
The regulator linkage is set up by adjusting the length of the rods connecting the main throttle arm to the throttle body and injection pump levers. The pump has a position indicator as shown below
To indicate the position at the throttle body I attach a protractor to the lever and use a pointer made from coat hanger wire!
The relationship between the throttle body and pump angles is not linear, for example when the throttle body is at 2.5 degrees the pump must be between 4.4 and 5.1 degrees, at 20 degrees on the throttle body we need between 28 and 31 degrees at the pump, the differences then narrow untill 80 degrees on the throttle is 79-82 on the pump. The geometry of the linkage allows this non linear relationship so long as the rods are the correct lengths. The challenge is setting these right while making sure you still acheive full throttle openings with your foot flat to the floor and the kickdown switch activated.
The first time I set mine I found I only had about 80% throttle so adjusted to get full throttle, the difference was pronounced, as were the chirps from the tyres:)
I to am interested to see if the car will in fact run at all with this pump, I purchased it from a M-100 group member as good to go but of course with no warranty. It LOOKS in good condition but that means nothing other than it hasn't been tampered with.
Whatever the outcome with this pump the old one was leaking so badly it had to come out. Even the gasket between the pump and the block had evidence of a decent size leak and while it has been sitting on the garage floor it has leaked most of its oil out.
I'm having the old pump rebuilt anyway so if this new one works well I'll have a good spare. It maybe extra work but if it keeps my car on the road I'm happy to gain the experience, it will be easier next time:rolleyes:
I took a day off work today to try and tune the new injection pump in the 6.3 and hopefully get it running right. Before I installed the pump I set the idle mixture thumb screw to as close to the middle of the range I could, I did this by turning it all the way one way then all the way back the opposite way counting the clicks as I went, of course then halved the number of clicks counted and went back to "centre" the thumbscrew is a sod to get at when the pump is in so I wanted a baseline to start from
The thumbscrew
How to access it with the pump installed, I should add one cannot simply turn it to adjust the mixture, you have to push it in against spring pressure to engage the screw to the rack:( I've seen vets do this sort of thing...
All back together
I removed the coil lead, switched on the ignition to run the fuel pump and prime the injection pump with fuel then cranked the engine on the starter until oil pressure built up to ensure the pump had an oil supply, all good so I replaced the coil lead and it fired up instantly and ran well but was again rich,
I backed the mixture thumb screw to as lean as possible then added 2 clicks at a time until I had 3% CO2 at idle in gear.
After a brief test drive I was impressed with the changes, it feels much stronger and smoother, pulling to redline as crisp as. Time will tell but I feel the early signs are that I have a good pump in there now, no oil in the valley, no smoke from the exhaust I can see from the drivers seat. A fuel and oil consumption test will be in order, now to go for a run and see how it goes:D
S Direct injection Articles 1
A water pump Mechanicals 7
Oversize Replacement Wheels & Cleaning Exteriors and Body Repairs 3
Styria 6.9 Carpet Replacement Interiors 1
Oversize Suggestions for a daily replacement Talking Torque 20
c107 Monovalve replacement Mercedes W126 0
L Clock Replacement Mechanicals 5
WGB RH Sway bar chassis bush replacement in RHD 6.9 Technical Information 0
abl567 6.3 Camshaft replacement Mercedes W108 and W109 0
Styria Replacement of four doors - 6.9 Technical Information 25
BenzLover Engine radiator replacement Mechanicals 3
A Aircond compressor replacement Mercedes W116 32
