Which Bosch fuel pump do I need for my 450SE D-Jet 1975
More threads by B13
May as well buy a new one for Team116 #2 450SE...
Is it the Bosch 910 that I need to use or another one?
Dude selling them on eBay says the 910 is for 450SE 1976 onwards (which would be K-jet)... if so what goes in the 1975 with D-jet?
Thanks
Hi B13, sorry I kept missing this post. If the engine number of your car is 117.982/3, the Bosch number should be 0 580 464 005. I am reasonably confident that I am correct, but will try and double check tomorrow. Regards Styria
Oversize Bosch Non-resistor plugs NLA? Mechanicals 0
260ebenz Bosch wipers Talking Torque 0
260ebenz Bosch wiper blades Mechanicals 0
BenzBoy Bosch Websites and Links 0
BenzBoy Bosch Mechanicals 2
BenzBoy Early Bosch Websites and Links 0
c107 Old Fuel Mechanicals 24
A fuel tank Mechanicals 3
