How to Remove the Silver Grille at the Base of the Windscreen?
More threads by Lukas
Hi all,
I can't figure out how to get this bit off - help!
Wipers are removed, and there are 4 black plastic lumps on the engine bay side that don't respond to prying etc. The other long edge is under the windscreen seal. Does the screen need to come out? Is there a mystery screw under the dash somewhere?
Thanks
The black lumps are a plastic plug/retainer affair - push the centres into the plug and they will fall out the back into the wiper-motor cavity, remove the plugs as the plastic centres hold the plug tangs open. They are brittle and will probably break, btw.
I've been lucky with my cars and have been able to recover the centre pins from the wiper-motor cavity and re-use the plugs, but I'm pretty sure they are a single-use item.
Hope this helps,
6.9forever
Sunshine Coast
If they break, will a self-tapper or rivet do as a replacement? Is it worth getting the grille off to clean out debris (read: "rust/moisture trap")?
David, the holes are really a bit big for both rivets and self tappers. The proper plastic fittings can still be bought and are certainly the preferable option. In addition, there is one other type of plastic (bung) that can be used - it is the one (one of several) that pin the metal front door rubber metal strip to the front section of the door.
In my view, there is not a lot to be gained removing the metal grille for cleaning out purposes - most debris finds its way to the two drain holes, but the exterior rubber spouts located against the firewall are closed up and trap the dirt inside them. On 6.9s, the unit on the right hand side located behind the rocker cover is extremely difficult to remove and replace. A lot more dirt usually finds its way to the rubber bellows that connect to the heater fan located behind the dash top. I might be able to locate a pic taken when I removed the dash a few years ago which shows the amount of small leaves etc. that I managed to blow out. Regards Styria
L
Having successfully removed the parts car one (thanks B13), I'd suggest to others not removing it unless you need to, because:
  • The aluminium is soft and easily damaged
  • You may compromise the windscreen seal by removing and replacing the grille - if you can even get it back under the seal
If you do remove it, I suggest wearing gloves - I didn't, and had bleeding fingers from the sharp bits under the grills.
I caught 3 of the 4 pins from the black plastic doohickeys, the fourth vanished down a drain hole:(
What really scared me was the radiator hoses that went to/from the heater box - they initially felt solid (I presumed perished), but squeezing a bit more made crunching noises and revealed the hoses to be soft and in good nick. The crunching was all the crap that had built up inside the hoses breaking free and entering the cooling system:(
Annoyingly, removing the grille didn't reveal the wiring to the HVAC fan behind the glovebox that I was originally looking for.
PS: Grot does accumulate there, but most of it could be dislodged just by blasting a hose in there and flushing it down the drain holes, so no need to remove the grille for that.
Could someone post some pics with the grill removed, so others know exactly what can be achieved with it out of the way?
Lukas - even with the front screen rubber in place, the grille can be refitted, albeit it's a little awkward. Usually, using Inox as a lubricant, you can left the rubber lip back over the grille - sometimes a second pair of hands will help.
Oversize - the layout of the body under the grille is not particularly conducive to taking good photos. Unfortunately, I not long ago re-fitted the grille to Gleaming Beauty. Possibly Lukas would be in a better position to take a photo. Essentially, all you have under the grille are of course:
1) The windscreen wiper motor that hides a greater part of the opening.
2) The two heater hoses, and the spouts for the windscreen washing.
Say once they are removed, there are fairly large drain holes at each end that exit into the engine bay with those large rubber bellows accepting any debris or water. Quite often they are closed off at the end and they need to be opened up to remove any debris.
There is also an additional opening that leads to the bellow connected to the heater fan. That can often fill up with debris as well. As previously stated, I am endeavouring to find a photo I took when cleaning out Gleaming Beauty some years ago. Hope all this helps. Regards Styria
motec 6.9 Things to remove before selling Gumtree/eBay/Facebook Listings 11
B How do I remove the engine fan? - 450SE Mechanicals 4
B Heater control panel in the console - how do I remove it? Mercedes W116 4
Oversize The Silver Pig Talking Torque 0
S Painting Silver Alloys Articles 12
c107 Trip to the Arctic in a cheap Silver Shadow Websites and Links 2
motec 6.9 RR Silver Cloud Icon built Road Tests 5
Styria Astral Silver 6.9 Gumtree/eBay/Facebook Listings 4
Styria Rolls Royce 2015 Silver Ghost Road Tests 0
motec 6.9 Silver Arrows/Auto Union Goodwood Talking Torque 0
Oversize Silver Aussie 6.9 for sale Gumtree/eBay/Facebook Listings 24
Oversize Silver AMG 6.9 Mercedes W116 9
260ebenz Silver Stars for sale Websites and Links 0
260ebenz Mercedes Silver Arrow Concept Articles 0
Oversize Silver Arrow Mercedes W116 13
motec 6.9 RR silver Cloud 11 Shannons Gumtree/eBay/Facebook Listings 2
motec 6.9 Rolls Royce Silver Seraph Gumtree/eBay/Facebook Listings 11
motec 6.9 1949 Silver Wraith Talking Torque 2
motec 6.9 1933 Peirce Arrow Silver Arrow Talking Torque 1
motec 6.9 1959 Silver Cloud convertible Talking Torque 1
motec 6.9 Uniquecars RR Silver Seraph Talking Torque 5
Oversize Silver 450SLC for sale Gumtree/eBay/Facebook Listings 1
Oversize Silver 6.9 for sale Gumtree/eBay/Facebook Listings 8
motec 6.9 1954 silver wraith vignale saloon Talking Torque 0
motec 6.9 1954 Silver Dawn for Michel Talking Torque 4
motec 6.9 Dr Q 6.3 Silver Pig Motorsports 3
Oversize Silver 6.9 for Sale Gumtree/eBay/Facebook Listings 11
Fotografa Silver Arrows Racing - Some awesome photos... Mercedes R/C107 1
SEL_69L Black Or Silver - Which Do You Like Better? Exteriors and Body Repairs 35
Styria Astral Silver 6.9 body preparation Exteriors and Body Repairs 23
Des Silver AMG Mercedes W116 5
300SDude Ding in my grille Exteriors and Body Repairs 24
B Cheap 6.9 on eBay with blue wheels and grille - for restorers Gumtree/eBay/Facebook Listings 22
Michel Unique Grille Gumtree/eBay/Facebook Listings 29
Des 100000k's grille badge for sale Gumtree/eBay/Facebook Listings 6
R 116 grille trim Exteriors and Body Repairs 5
Des Grille Badges Talking Torque 21
