Distributor Cap Wanted
More threads by BAR
After parking my car on a friends lawn after a long drive in the wet, I found that it didn't want to start the next morning.
Opening the bonnet revealed that she had 'sucked up' a huge amount of moisture from the wet grass (after all it's been raining on and off in Sydney for nearly 3 weeks) and there were droplets of water everywhere.
I got out the trust WD-40 and started the process of applying it on all electrical contacts.
Still she didn't want to start, so I removed the dizzy cap. Well it was wet inside and got a spray of WD-40. Back on she went and zooom it burst into life.
What I have observed is that the dizzy cap is cracked, so I am in need of a replacement.
Anyone who has a 450 SE cap for sale please send me a pm or call me on 0457 39 64 65.
Thanks
Thanks
Hey Brian,
I sold mine only a couple weeks back.
However, brand new from MB Spares they are very cost effective, and also for piece of mind of a new one - it's worth it.
Cheers,
Cam.
I guess you still haven't been able to sell it?
Hi Michel
Still have it in my garage. Hope all is well with you and your fleet!
Des
Australia
Why not somewhere like supercheap?
surely?
Last time I had a Mercedes and needed a dist cap, it was a few years ago granted but $25 for a Champion or something like $60 for a Bosch.
they are just a throw away item, bit like putting used spark plugs in a car or wiper blades
Kind Regards
Des
If you just want one that works, I'd go to the wreckers and grab one. Early W126 V8s use exactly the same part.
Indeed, for a long-term solution, new is the only way to go.
You still have mine, right? :)
Yep, still got yours mate. :) Thanks for reminding me. Will get your parts together and head over your way later in the week. :eek:
I called Bosch Australia and they have NIL stock.
Any ideas where one could be found?
Can anyone tell me the difference between these two parts: or can either one be used on a 1976 450SE?
App: Direct OE replacement 1976 Mercedes Benz 450SE
Brand: Bosch Distributor Cap
Part#: W0133-1616993
Description: Eng: -056536, Bosch 0.290.004.500 Threaded stud terminal : with black cover.
Fits: Direct OE replacement
Type: Black
Part#: W0133-1619522
Description: Eng: 056537-, Bosch 0.290.004.505 Threaded stud terminal : with black cover.
Type: Black
Hi Bar, I am pretty certain I have located a unit - but it is just plain bakelite without the black plastic cover. The price $25.00 plus postage to Central Coast. Please give me a buzz when convenient. Regards Styria
Sent you a PM regarding postal details.
You can reach me on 0457 396465 any time.
regards
Fotografa
Paddington, Sydney
Brian, the 450SE actually used 3 different types of Dist caps during it's production. What year model is yours? Does it have the threaded connectors?
Some comments on here saying that it is just a throw away item, are true, BUT it plays such an integral part in the proper functioning of your car, so why install anything except a new OE one? Bosch was the OE supplier.
Let me know what type, and I can tell you how much for a new Bosch one straight away.
Anything you save on a cheaper, or used one, will be eaten up by the costs of either poor running, or replacing it soon when it dies.
J Euro Distributor Part Number Mechanicals 2
BenzBoy Swissvax - new distributor Exteriors and Body Repairs 1
3 distributor cover Gumtree/eBay/Facebook Listings 0
B V8 distributor rotors Mechanicals 13
TJ 450 6.9 Distributor Rotors Mechanicals 33
I Correct spark plugs and dizzy cap...??? Can’t find online Mechanicals 3
B Vacuum systems: doors, boot, petrol cap Mechanicals 3
A Wanted to Buy: 350 or 450SLC Feb/March 2022 Mercedes R/C107 13
Michel Wanted W108 doors Gumtree/eBay/Facebook Listings 2
B Wanted: Turbo diesel car Gumtree/eBay/Facebook Listings 15
Michel Wanted Mercedes W116 12
Michel Wanted for W116 Gumtree/eBay/Facebook Listings 22
mrkozzy w108 boot lid wanted Gumtree/eBay/Facebook Listings 3
Michel Wanted floor mats for W116 Gumtree/eBay/Facebook Listings 19
motec 6.9 wanted amg spoiler Exteriors and Body Repairs 6
