Correct spark plugs and dizzy cap...??? Can’t find online
More threads by irvine
irvine
Maroubra, Sydney
Hey AGAIN everyone (I've always loads of questions), again tinkering with the engine. Since I bought the car a few weeks ago its had a noticeable "miss" especially upon a cold first start. so today I pulled the plugs and of course number 3 was heavily sooted and had a carbon build up. need to replace asap....
also the dizzy cap had some damage inside, almost like someone hadn't fitted it correctly and the rotor had marked the side of it. luckily no rotor or dizzy damage.
The plugs fitted where NGK BP4ES which when I looked up where incorrect. Am I right in finding NGK BP6ES...???
Also i cant find a part number on the dizzy cap or find a number online, whats the correct dizzy ap i should be fitting...???
sorry its for a '74 280SE.
kind regards,
neil.
Modify message
kind regards,
neil.
Modify message
Hi Neil.
A BP4ES is a hotter version of the BP6ES. Its a non resistor plug which is what you're looking for. resistance is built into the leads.
If its just one of them fouled, may be because the cap is a bit stuffed? One of the Mercedes parts suppliers should be able to sell you the right cap. I would also check very carefully the suppressors at the end of the leads. the misfire in my 300SE was caused by spark leaking out of cracks in the suppressor. You could see it quite clearly if you run the motor at night.
Would be a quick and cheap thing to get a cap, new set of plugs and check the suppressors and see if that fixes the problem.
