450 with no spark
More threads by Nudge
Nudge
Australia
I have a 450sel that cut out suddenly and would not start. An hour latter it started. A few days latter the same thing happened again, only this time it still wont go. A quick check found no spark. Having an identical car I started swapping bits. So far I have changed the coil and the control box. Once they had been swapped with the other car, the other car still runs but not the one with the problem. I checked the green wire from the dizzy for conduct, thats ok as well. I am getting power at the coil when cranking, but no spark. If anyone has any idears, I'd be very greatful.
Nudge.
Immediate thoughts would be HT coil lead, cap problem or rotor failure.
I don't know what does the triggering but I would look for an earth between trigger or green wire and earth.
I had a guy that had a 280SEL that was misfiring. Put your foot down & it would wanna cut out. It would only increase speed if you pressed the throttle down slowly. He swapped parts from another car with no luck. He spent at least $1500 attempting to find the problem through other repairers, before he brought it to me. After checking (not replacing) the fuel supply, I had it put on an analyser which revealed a faulty coil. I now refer to the job as the $2K coil! :eek:
One of my cars is misfiring & I too have swapped parts to no avail. When I have the time to check it properly, I'll start from the basics & then put it on the analyser (not mine). It may turn out to be yet another coil. My Fairmont is lacking power & surging both on LPG & petrol. It's always done it on petrol, even after the fuel pump was replaced when it shorted out. I suspect the coil pack is playing up on that too. Coils can do some funny things before they fail altogether, so I'd be looking very closely at that....
Nudge
Nudge
Australia
:D Yay. found the problem. It was a faulty immobilizer. In WA. we are required by law to have immobilizers fitted to our cars. (This is because the gov. did'nt want to punish people who steal cars.) Anyway the immobilizer cuts out two of the cars electrical systems. For some reason the immobilizer still apears to operate, as the light goes out and the starter will work. But the ignition was still disabled.
Good news for WA owners. Checked the gov. web site on immobilizers, and only cars under 25 years old have to be fitted with an immobilizer.
Nudge.
Often, when electronic or electrical systems is when they start to fail, and before finally failing altogether, they often work intermittently. If your car stops again, try changing the fuel pump relay. They are reasonably cheap to replace. These days I carry a few different relay boxes in my glove box.
Styria can vouch for some of the sagas I had in this regard!
Well Nudge, you never mentioned the immobilizer. I had read your post, and all I could do was to scratch the baldy patch on my head ! I am glad you got the problem sorted. Just as a matter of interest, why not tell us a bit about your car, the work you have done, or may need doing, and perhaps a couple of photos wouldn't go astray. Thanks for posting. Regards Styria
Oversize Interesting 450 at Hanging Rock 2015 Mercedes W116 2
Styria 6.9 with 450 differential Technical Information 30
Styria 350/450 Exteriors and Body Repairs 6
garrye 450 slc pics Mercedes R/C107 3
garrye 450 slc breaking down under acceleration Mercedes R/C107 6
SELfor50 450 SLC - Engine Conversion Mercedes R/C107 7
TJ 450 TJ 450's 6.9 Pics Mechanicals 7
Phantom 1974 SLC 450 for sale Gumtree/eBay/Facebook Listings 6
WGB M117 450 - 370bhp Motorsports 7
SELfor50 450 SE - Gold Coast - "Pimped Out" Gumtree/eBay/Facebook Listings 10
A 450 SE windsheild wipers - original colour & length? Mercedes W116 6
SELfor50 450 on LPG Gumtree/eBay/Facebook Listings 1
SELfor50 Gold 450 in QLD - Good looker Gumtree/eBay/Facebook Listings 9
D For sale w116 450 SE Gumtree/eBay/Facebook Listings 6
J 450 For Sale Gumtree/eBay/Facebook Listings 1
Michel 1977 Mercedes-Benz 450 SE (Is that Cheap?) Gumtree/eBay/Facebook Listings 7
Michel NOS Radiator for 450 !! Gumtree/eBay/Facebook Listings 5
SELfor50 450 Sel - Bargain!! Gumtree/eBay/Facebook Listings 4
I Correct spark plugs and dizzy cap...??? Can’t find online Mechanicals 3
Styria Fouled Spark Plugs Technical Information 1
BenzBoy Spark plugs? Mechanicals 8
BenzBoy Refresher course in reading spark plugs. Mechanicals 1
Styria Spark Plug Suppressors - New Gumtree/eBay/Facebook Listings 0
