C107's 1981 240D W123
As I posted in the Projects Thread, I recently purchased a 1981 240D. I wasn't really looking one, but this super original car fell into my lap and I couldn't say no to it.
I've been enjoying driving it so far as its a good contrast from my other cars.
2024-04-25 13-51-15c.jpg2024-04-25 13-51-50.jpeg2024-04-25 13-52-01c.jpg2024-04-25 13-53-49c.jpg2024-04-25 13-54-08c.jpg2024-04-25 13-55-08.jpeg2024-04-25 13-55-29c.jpg2024-04-25 13-56-12.jpeg2024-04-25 13-56-19.jpeg2024-04-25 13-56-21.jpeg
Patrick was asking about specs for the 240D:
displacement: 2399 cm3
Bore: 90.9 mm
Stroke: 92.4 mm
Compression ratio: 21 : 1
Horsepower net: 53 kW / 4400
Torque net: 137 Nm / 2400
Top speed: 138 km/h / 86 mph
0-100 km/h (s): 24.7
Economy (l/100km):
extra-urban (up to 100km/h): 7.6-9.1
city: 9.7-11.6
highway (up to 140km/h): 11.1-13.3
average combined: 9.2
The 240D is a true gem.
How do the specs compare to my E250 CDI Estate?
Well:
Displacement: 2.143 litres
Bore: 83mm
Stroke: 99mm
Compression ratio: 16.2:1
Twin turbo
Horsepower: 150kws or 204hp
Torque: 500nm or 369 lb.ft
Top speed: 144 mph or 230kph
0-100 kph: 7.5 seconds
Economy (l/100kph)
Urban: 5.5-6.4
Highway: 3.9-5.1
Combined 4.5-5.1
Emission standard: Euro 6
Well:
Bore: 83mm
Stroke: 99mm
Twin turbo
Economy (l/100kph)
Urban: 5.5-6.4
Highway: 3.9-5.1
Combined 4.5-5.1
That is a mountain of torque.
Huge difference, of course. It amply illustrates the progress in engineering attained over the last thirty five odd. years. Regarding Benz Boy's car - I have reason to believe that the Diesel engine can experience certain problems with the particle (?) filter - I wonder if there is any truth in that. Regards Styria
Styria, some brands have problems with the particulate filter. Generally this is not an issue for Benz. The key to keeping the particulate filter clean is to mix longer trips with short town runs - which I make a point of doing. It is necessary to use low ash oil to MB specifications. The other key is to use an authorised service agent who can run a cleaning programme if necessary when the vehicle is serviced- again something I do.
All very good comments Brian.
Modern diesels need to be maintained professionally for sure.
Brian, does your car run AdBlue?
Cars that run AdBlue have less issues with their DPF’s, but as you stated, good runs are desirable for all modern diesels.
Next was the under bonnet insulation. I was already doing the 107 (will post some pictures of that soon) so did the 123 at the same time.
2024-05-18 20-33-28.jpeg2024-05-18 20-47-53.jpeg2024-05-18 21-22-37.jpeg2024-05-18 21-34-02.jpeg2024-05-18 21-41-25.jpeg2024-05-18 21-41-25.jpeg2024-05-18 21-57-00.jpeg
Under bonnet insulation king!
Bryce, can you see inside the rocker cover?
Shiny metal?
As long as the internals are clean, doesn’t matter how the oil looks, it means it’s doing its job very well 😊
