seat repair
My 107 drivers seat has sagged. Styria has some suggestions. An article in "Peach Parts " suggests that using a Polyester sheet instead of the Horse Hair Insert gives better support ( $10 item ) Plus use Pool Noddle ( round firm foam lengths ) to support the spring base ) Has anyone tried this ? May not last as long as using the original parts but as a week end car the cost savings are not insignificant.........Sean
Hello Sean,
Contact Brent Parker Motor Trimming in regards to the seat repair.
Perhaps a Google search might find an automotive seat repairer in your area hope this helps?
pulled the seat today and it looked like the day it left the Factory. The Horse Hair insert was firm and the springs looked and felt fresh. I was able to raise the cushion an inch or so by inserting some hard rubber packing between the spring base and the Horse Hair Pad , spreading the load across all the springs.
The hardest part was R & R-ing the heavy seat, 4 side bolts and 2 hidden screws.
Now little Wifey should be able to see over the steering wheel. Like me, she has shrunk an inch or two with age, and gravity eventually gets you !
....Sean
You have done well, Sean. Your method is certainly one that can be made to work. As a matter of interest, the callicoe supporting the stitching of the pleats - is it still in good condition ? Thanks for keeping us up to date. Regards Styria
Yes everything looked good Styria. Even the original Factory label with P/number still there after 33 years. I'm now inclined to believe the mileage at 70,000 odd thousand ,as the steering wheel also shows little wear round the rim. It's a Hong Kong Import and as the person who brought it in said...
" Where can you drive to in Hong Kong ". The car has been a weekend Hobby car ever since and garaged all it's life.
The luck of the Irish !....Sean
J Repair a broken seat spring Interiors 8
J Drivers seat stuck at full height adjustment. Mercedes W116 3
S seat belt holders Mercedes R/C107 4
260ebenz Electiric seat switch Mercedes W126 12
260ebenz Silicone spray seat belts Interiors 13
Oversize Seat upgrade Interiors 2
BenzBoy Advice on how to clean a light coloured seat belt? Interiors 25
WGB Another take on sagging seat bases Interiors 7
Martin280s Seat bases Interiors 6
BenzLover Re assembling the electric seat switch! Mechanicals 4
WGB New rear leather electric rear seat finally sorted. Interiors 6
WGB Delayed but welcome arrival of new rear seat leather Interiors 5
Oversize Rust Repair Panels Exteriors and Body Repairs 2
Oversize 300SD Collision Repair Video Mercedes W116 3
260ebenz Accident Repair Costs Talking Torque 16
D Minor rust repair / panel beater Melb? Exteriors and Body Repairs 5
