Paintless Dent Removal
Perhaps Michel or Styria have a contact ? I tried myself using a Kit that pulls dents out using a glued on plastic piece which is then pulled out by a lever type pumping action.... Made it worse, a little knowledge is dangerous !
L Pickles Scratch & Dent Gumtree/eBay/Facebook Listings 1
