Memnoch 6.9
More threads by motec 6.9
While it has been almost 3 years since my vehicle accident. Nothing has happened on my car with regards Progress as quite simply money ran out. And being limited to work I could do with a right arm that has no strength limited employment options. I can confirm I have still ownership of the vehicle workshop with car know of my situation. And once everything is settled I will endeavor to complete work on my car.
Oh and I have found myself a Butler 4 channel Valve car stereo amplifier to fit to my 6.9 with Focal speakers in original locations and will add bluetooth to my Mexico tape deck.
Also once I have car back will fit my billet CAD Scanned 85mm throttle body to car and replace WUR with FrankenCIS . To allow full electronic control over AFR. That should hopefully allow my car to smash through over 300hp at the wheels.
Throttle body and FrankenCIS pictures
Extractors
No problem and it currently makes 255.6hp at the rear wheels.
Before I took it of the road I took it to Kwinana dragstrip in Perth with the Horsepower it currently makes from Extractors and exhaust. Bear in mind it is a High Compression Euro 6.9 it did this time 14.24@97.21 mph is current 1/4 mile.
You may enjoy this dyno run was after extractors and duel exhaust. Still had 14 inch Bundt rims on car and tyres it had for 20 years while sitting. Smoked them on dyno while strapped down. https://youtu.be/Y6VAxFI60e0
Great to see you’re back Geoff!
May have to change car name to the Super Pit. Or how about Stetson as it gets about 10 Mile's to the gallon.
I like Stetson, then if you get a W123 you could call it Fedora...
Years ago I owned a W123 280 manual it sadly was Carb version but was a great car.
Well as some may have seen on Faceplant I made a trip into Perth today to see Daren with my 6.9 and discussed recommencing work on my car. He is now working on when car can be fitted into a slot which will be next year as he is booked out a fair way . But finally I can say I'm moving forward helped along the way by me becoming my mothers career last year . By that I mean she has been on my case since last year to do something with my car
motec 6.9 7 years since this video off Memnoch Mercedes W116 1
motec 6.9 Memnoch Mercedes W116 143
motec 6.9 Memnoch 0-100 Road Tests 22
