Glass polishing
Low sun shows up all the sand blast marks on the screen.
Is it possible to have them polished out ? Claying just cleans out the ingrained dirt. A new screen would be nice, but i think insurance would not cover this unless the screen was cracked ???:(
Sean,
I’ve never seen a sandblasted screen restored.
Tell the insurance company it is unsafe when driving into the sun.
But check your insurance policy, as a lot have a free windscreen bonus over a certain number of years or so.
Hammers are cheaper than windscreens, on the off chance that is relevant.
AutoGlym do make a great polish I have used the polish on all of the glass for the 300SE and the C220.
The C220 windscreen does have stone chips and it is the original screen.
I will have to replace the screen best to ring around and get quotes.
If you decide against a new screen have a chat to Ralph Moore. I had a side window polished to remove a very deep scratch and the job was a great success. A few years ago Porsche used to do it as part of their basic service but I suspect they have dropped that now.
Bit the bullet and and used mild paint cutting compound and polished it off with a glass cleaner. Screen now very clean, and the sand Blast pock marks now not very noticable. I can live with that .
Next job is to spruce up the Alloys. Usual kerb damage under the plastic rim protectors. They are stuck on and not very successful.
At $150 per Rim I will attempt a home repair. I have the tools to do the job.
All advice gratefully:) received.
DREADNOUGHT
Respectable
Geelong
I have just watched a YOUTUBE video on this its called - REMOVE BAD SCRATCHES IN GLASS...FOREVER!!! the poster is Sweet Project Cars, he has quite a few interesting videos. Hopefully the link works, if not just search you tube for the video or poster. Regards Maurie.
https://youtu.be/k1B_puVXtxk
Gents,
I have seen scratches removed and some quite bad ones at that, but Sean’s original post talks about a sand blasted windscreen, quite a bit different than a localised scratch.
Thus my comment I’ve never seen a sand blasted screen restored.
But of course someone may have gone to the trouble and done it to an irreplaceable screen?
Can be done commercially with a water cooled 4 inch disc polisher, using 20,000 to 50,000 grade tin oxide (white), or Cerium oxide (brick red). Both oxides have a Mohs hardness of around 8.5; windscreen glass is around Mohs 7.0.
Gem facetors (I happen to be a gem cutter), use these oxides for polishing the facets on cut stones, so I am familiar with the polishing powders that are used , and the grades used. I have cut and polished about 80 faceted gemstones.
There are specialists out there, who make a living out of polishing the wiper score marks from automotive windscreens.
I have successfully removed wiper score marks from the windscreen of my 6.9, using hand rubbing, but it is an awfully slow and relatively messy process. An electric 4 inch polisher is OK for this process, but it must be water cooled, or the windscreen will crack due to localized overheating. I used 20,000 grade cerium oxide; 1/2 kilo bought from Naxos Chemicals.
