First drive with new timing chain - and other ramblings
More threads by WGB
Finally got my 6.9 back on the road today with the air-con re-fitted (but not pumped up yet), driveshaft repaired and re-fitted , new 300K AMG replica speedo ( which is actually really good because I can now see up to 120k through the small wheel ) and new timing chain and tensioner.
End result after change of chain was 2 degrees of remaining "stretch". I decided to run it for a few thousand K and then re-check and correct with ofset keys when it is at 4 degrees.
Ran the fuel pump by turning the key with the transmission in gear to prime the K-jet (The fuel lines had been opened to remove the LH cam cover) and it kicked over and started on the first start. Then re-set the ignition timing.
Impressions of a brief drive -
1) Idle is now almost as steady as my 450 with almost none of the previous wobble.
2) Noticeable reduction in general engine clatter
3) Improved low end torque and now feels like rear wheels can be spun off idle if provoked.
4) More urgency at about 3,500 revs and up but I didn't push it too much until new chain settles into old cogs.
Flushed with success I removed the drivers seat, dismantled it, removed the squab cover, put some extra padding into the side bolsters (which were a little under-stuffed) with foam and then replaced the metal cleats that hold the central portion of the cover to the "Horsehair" with some new smaller diameter wire.
When I recovered them over Xmas several of these were missing off the old driver's seat squab and the only wire I had available was a little too thick and a couple of the fixings were palpable under the leather and in one spot where my large A^&e sat there was a risk that one might rub through.
Any way all is now well and I hope with a pump up I might have my aircon back as well as having my car back to driving condition.
Des
Australia
Dear Bill
Now you have increased your speedometer from 260 to 300, we expect to see engine improvements to see your car near 300k's per hour.
Excellent Bill. That's exactly the engine improvements I noted on my red car with the new chain.
Hi Bill, that's interesting - I am talking about smoother idle and better pick up etc.
The 6.9 Maintenance Manual does refer to adjustment of a new timing chain after 20,000 kilometres, so your intentions to do so should really finish off the job nicely. It will be interesting to see how long it will take you to post that mileage. Regards Styria
You seem to have done a fair bit all around Brother Bill,
Are there any other projects on the horizon (with the AMG)?
1) I have a set of subframe rubbers and rear arm rubbers but had enough to do this trip and they are not critical.
2) The rear automatic oil seal does not leak in normal running but does when sitting on the hoist for a few days - I guess a combination of the angle and the fact that everything drains back into the A/T sump - so a new oil seal is required at some stage.
3) I would like to do the front subframe rubbers and lower arm rubbers in the front suspension
4) Exchange the slowly delaminating rear window for another good one I have already.
5) Get new leather for the reclining rear seat to match the new fronts.
6) Tidy up a few bits of paint and put in new front and rear(I have already done the sides) sunroof seals.
That should keep me busy for the rest of the year, Michel.
Michel This Week's Test-Drive - Genesis GV70 EV Road Tests 10
Oversize New Drive-In Indoor Cinema! Websites and Links 2
c107 MBCNSW Drive Car Show Photos 2
S Ferguson Four wheel Drive Websites and Links 21
J A nice day for a drive Articles 12
SEL_69L I Get to Drive my SEL 69L Again ! Mercedes W116 5
260ebenz 300SL drive Motorsports 0
260ebenz 450SEL 6.9 drive Mercedes W116 6
H Good Friday drive Talking Torque 9
Styria Drive your Ferrari Talking Torque 0
Michel A (fast) drive around Philip Island Websites and Links 2
Styria Rolls Royce Test Drive Road Tests 0
Styria Test Drive - 126 Coupes Websites and Links 6
260ebenz MB TV- Drive Elvis 600 Mercedes Talking Torque 0
Styria W116 - Quick Drive Road Tests 3
motec 6.9 SL63 drive Road Tests 0
motec 6.9 Motor Drive SL500 Road Tests 4
Michel SLS Drive Road Tests 46
Tony66_au Rolls-Royce 102EX: First Drive Websites and Links 9
Styria 6.9 You Tube Drive Road Tests 1
BenzBoy The Winter Solstice - Phantom Drive Day Talking Torque 5
TJ 450 Went for a drive in the 6.9 tonight... Mercedes W116 2
