Dora 2
So finally the real work starts.... My target ‘finish’ date is 9th September.
Tell us more
She's a 300hp (220kW) M117 with some interesting options including HPFE, heated orthopedic front seats, split electric rear seats and what seems to be a very cool factory alarm option with high security lock on the boot.
I found the car a few years ago in the Southern suburbs of Melbourne after a mate tipped me off and even from the poor photos I knew it was something special, so I swooped. I wasn't 100% sure it was the 220kW engine, or that the hydro was functioning until I took delivery and I was able to take a closer look. I was over the moon to find the tri Y exhaust and took a quick glance at the front end and thought my dreams had come true, when I saw the struts still fitted. I found it amusing that there were signs of a previous Defect Notice on the windscreen, which probably prompted the PO to sell! I think I got lucky since it seemed the PO didn't know what a rare car he had....
I parked the car for 6 months being distracted with other projects. Re-focused I was able to do a bit of work on her and got the engine running again. The import plate says 1987 but I think it's actually a later car. I thought it had originated from Hong Kong or Japan but a parts supplier said recently it was from South Africa. On closer inspection of the front end something didn't look right and after some research I discovered one of the previous owners had replaced the front struts with 6.9 (or early W126) ones without the third hydro line into the lower ball joint. Presumably because the correct ones were probably NLA new and pre-loved ones were impossible to find....
So began my search for parts and this is what I've been banging on about for so long. Rare parts are VERY hard to find and your patience can be seriously tested. I managed to track down the correct speedo head in the US (thank's BHW) and then I moved onto my long search for struts.
But first I had to move everything to another storage facility.....
I found another HPFE full hydro car, but upon delivery I found one of the front struts had been used for parts and wasn't complete. Without both, I might as well have none. I tried all my contacts OS, including Mercedes Mike who sold a HPFE 560 with spare struts, but I was having no luck whatsoever. Searching the part numbers generally showed suppliers who were advertising new ones for sale, but when asked about actual stock they'd admit that they had none and they were NLA. I did manage to find a ball joint from Styria (thanks) but it needed a dust boot and I sourced a whole strut from OS, but it was in poor condition with a missing metal cup and buggered bump stop.
After searching the net like a madman for 6 months (or more) I managed to find some in Germany for a reasonable price. Trying to explain to someone in German that gas cells cannot be sent air freight and that they must be removed from the struts before shipping was a challenge....
Anyway, it's full steam ahead now as I get each system on the car back in operating order. The list is long and I keep finding problems to rectify, but I have to prioritize and realize it won't be perfect anytime soon. I'm under pressure to get it ready in time, but that's generally when I work the best.
I called her Dora 2, since Dora 1 (a Euro 6.9) will be sold with too many projects on the go. I liked the name Dora, since it was the same name given to the world's biggest rail gun; made in Germany of course!! :cool::cool::cool:
The front bumper is stuffed and will be replaced with an Aussie one. To my surprise the mounts are different to the Sth African ones which have energy absorbers & bigger mounting studs.
The grille will also be replaced due to a rusted frame & broken insert. Cosmetic yes, but annoying me they do!
Some new cells have arrived... Note the different part numbers
Note the engravings including build dates & pressures. The 6.9 was supposed the have blue dot 60Bar ones on the rear which is different to the red & green dot ones here.
Woaw
Lots of hard work and more to come.
Good luck with the project
I think it's a later car since it has an airbag and side indicators. The cracked plastic hydro tank is now out along with the pressure reg and control valve. The filter was pretty nasty, but intact and the fluid definitely needed changing. More pix to follow.
I discovered the front rotors are worn out, along with the front pads. Another reason the car was probably sold by the PO. I thought the car had been in a fron collision due to the radiator support seam sealer visible and the radiator not sitting lower. It actually looks like someone has tried to jack up the car under the lower radiator support which bent it upward. It has had a rear end collision with an iffy repair but at least I haven't found any nasty rust (so far).
I have some new 18" Aero II Hammer wheels which will be polished shortly. I'm currently searching for better wheel bolts.
My understanding is that all W126 run on the same number series, so if the VIN Is not available on one of the russian vin decoder sides, you should be able to get a rough idea of when it was built by comparing with other cars. for example, three w126 cars I've had:
1989: #446528
1988: #392788
1986: #269877
The VIN is 322020 so maybe 1987 is correct?
The chassis is ok but the DSF door is shot no thanks to this thing...
Test fitting the new heels...
Oh no! Tuesday is strut day...
Mark, I admire your tenacity. I am sure you have experienced plenty of frustration but, at least, you have a plan to work for and targets to achieve. Good luck with this project.
As a matter of interest, do you still have plans for restoration/refurbishment of any of the 6.9s ? Looking forward to hearing from you. Regards Styria
Oversize Dora for Sale Gumtree/eBay/Facebook Listings 6
