componant location
Does anyone know where I can obtain the lay out and location of the various under bonnet sensors etc on the 110 engine in my 280 S L 107.
Also where are all the relays are located ? e.g. I eventually found the Fuel pump relay in the kick panel above the fuse box after all the web info said it was behind the Glove Box.
Pipes and hoses disappear under the inlet manifold to Gods know where.
In particular what is the the Vacumm canister at the rear of the inlet manifold for ? It has a vacumm tube from the air cleaner (at the rocker cover ) and two steel pipes also feeding it.
Other wise all is well, the car runs beautifully.
Thanks Sean
