Change your oil!
More threads by John S
I see what you mean. I have a colleague who has run his Honda Civic for 30,000 kms since new and has not changed the oil. He probably has problems and will not listen to advice. That's his problem...
Seriously though, if this happens at 60,000 miles then what is already there at the normal oil change interval? Regular changes must be good - they can't be anything but good.
Benz-Boy
Farkn hell!!! That's some crazy shyte.. Bimmer's ay?! That's pretty messy. I love it how the dude goes: "I need help, I seriously don't know what to do!"
Hahah..
Cam.
Man, that's disgusting. I bet there's a lot of cars that endure the same treatment.
I never did take a photo of it, but when I removed the oil filter from my 380SE's engine, I saw something quite ridiculous.
There was a "more recent" filter sandwiched between the "end caps" from the previous filter, plus the conical spring was missing. The whole thing just flopped around in there. I'm sure it would've worked extremely well!
Oversize How to Change Your Coolant Technical Information 22
Michel NEW Track Day Anyone? Change of date -- 7 March 09 Motorsports 14
G Colour change question Exteriors and Body Repairs 8
B W116 gearbox change to either W126 or Supra. Mechanicals 7
B Oil Changing Mechanicals 19
