Good evening all,
I finally got my 6.9 running again (of sorts) today. However, it still has a big missfire and runs very roughly, there is a characteristic put-put sound of a very rhythmic nature suggesting that at least one cylinder is not firing correctly. Ignition timing appears to be way off (retarded), as the "0" mark is way down at the diagnostic sensor. The reference point is up the top just under the w/pump, is that correct?
Bill, I noticed in one of your tutorial pics, your distributor rotor. Is that offset? Someone has fitted the standard M117 rotor at some point, could this be part of my problem? The distributor was, and has been, advanced as far as possible.
By the way, for those who were unaware, this is the list of work required and items that have been replaced/checked so far relating to this.
*Compression test - all withing 5% (according to my gauge!).
*Ignition leads replaced with the correct part, distributor cap replaced with known working part.
*Spark plugs changed before ignition leads - potential problem, plugs were dark grey/black in appearance (not wet).
*Full set of injector nozzles, lubricate airflow meter, clean out fuel dist. with carb cleaner etc.
*Timing chain will need to be replaced as it is obviously worn (original).
*New exhaust system installed (OEM).
*Valve train looks good, oil pressure is excellent.
